Timing belt change
haynes manual. and to tdc the cam, there is a little hole in the cam cover, that, when lined up with the hole in the cam, you can drop a pin, such as a tight fitting allen wrench into, and it will hold it at tdc. then you just line up the crank pulley, and slip on the belt.
pretty easy i have done it twice in a month, but there are 2 different belts with like 103 or 106 tooth count, i had the lesser of the two and got the wrong belt... remember dont loose that little crankpulley metal thing...
ORIGINAL: sacicons
actually, if you know where to look, I have yet to find one without them. of course i ussually work on the same 5-10 cars, so that might be part of it. but i know the 97 h22 has them, i know the b16a2 has them, the b18c has them, ls has them, and i know some single cams have them. ill see if i can get a pic.
I'm doing the same , is there any other way to undo the crank bolt my compressor / impact will not budge it, how about having some one hold the brakes while lossing the bolt with a long cheeter bar, would I break some thing?
Jon
Jon
thats the best way to do it, unless you have a flywheel holder, and have access to the flywheel. i usually use an impact, even though it is hard on the bolt, but i had to buy a big impact, like 565 ft-lb one, and i still had to hammer on it for a minute or two.
http://honda-tech.com/zerothread?id=649277
try this for a great blow by blow for timing belt removal
