Timing Belt / Water Pump Change. Now very Noisy
So I bought my car to a shop today to change my Timing belt/water pump/belts/ and seals. Its a 99 Civic Hx. Before I had the timing belt change it ran perfect and the idle was very smooth. After the timing belt change it makes alot of noise at idle but while Iam driving it runs perfect. He told me it was because my AC clutch Bearing is loose and so was my old timing belt, thats why it didn't make any noise before.
Could a loose AC Clutch bearing be the cause?
What type of noise are you hearing? Do you mean the idle is now rough?
If you doubt that the A/C compressor is making noise, remove the A/C belt to see if the noise goes away.
im calling BS on your shop guy.... he just screwed up and probably didnt tighten up the timing belt enough and doesnt want to pull it all apart again to fix it! IMO....
ORIGINAL: addiction2bass
if the timing belt is to loose then it could posibly slip a tooth and jack your timingall up...
dave_57204
Jan 27, 2008 10:16 AM
LIhybrid
Oct 13, 2005 03:04 PM
jjgarcia
Aug 22, 2004 07:39 PM
