Car won't start after timing belt and water pump change
Old Jan 27, 2008 | 08:30 AM
dave_57204's Avatar
Default Car won't start after timing belt and water pump change
Hey, I just did my timing belt and water pump change, Now my car crank but wont start. I am getting fuel, spark and compression. (did a dry compression test) I am not sure what the problem is, I have the firing order correct. Mabye the timing belt is off a tooth? When I try to start it it sounds like atleast one cyclinder fired up mabye to, then it stalls out. Any ideas anyone before I get to towed to the shop torrmow?
Old Jan 27, 2008 | 10:16 AM
Default RE: Car won't start after timing belt and water pump change
Double check your timing. You don't have to take it all apart again to do that. Remove the upper timing belt cover so you can see the cam sprocket. Turn the crank to TDC (the SINGLE notch on the crank pulley, not the group of 3, is lined up with the pointer). Check the marks on the cam sprocket. You may have to turn the crank around exactly once to get the top mark on top.
You can also have the firing order correct, but the #1 wire on the wrong terminal. When you have the engine set to TDC, take the cap off and make sure the rotor is going to wire #1.
vltnolia
Jun 29, 2008 07:07 PM
SpeedRacer_87
Jul 29, 2007 09:41 PM
POLYTHING
Sep 17, 2006 11:26 PM
LIhybrid
Oct 13, 2005 03:04 PM
smokingemcee
Aug 9, 2005 10:36 PM
