TIRE SIZE REPLACEMENT
Old Dec 28, 2007 | 02:08 PM
Click26's Avatar
Default TIRE SIZE REPLACEMENT
Hi All,
Appreciate if you can help me with little inputs regarding replacing a standard civic tire (195x60x15) with 215x55x17 would affect car's performance in terms of maneuvering,fuel consumption,impact to engine, andoverall safety of the car.
Quite new in driving andhaslimited knowledge in techie part...
Thank you very much!
Old Dec 28, 2007 | 02:34 PM
Type RB's Avatar
Default RE: TIRE SIZE REPLACEMENT
Go to Discount Tire's website and use their tire replacement computer. It'll tell you what sizes you can work with as far as the engine powerband stuff. Handling and safety are kinda relative - wider tires means bigger contact patch, which means better braking (usually) and more traction (usually).
Old Dec 28, 2007 | 04:21 PM
PirateX's Avatar
A 55 series tire is going to have too much sidewall if you are going to a 17" rim.
I would suggest 215/45/17 instead.
Old Dec 28, 2007 | 04:32 PM
Civic Si 00's Avatar
ORIGINAL: Click26
Hi All,
215/55/17 TOOOO High well Big (55) More likely it wont fit and wide. My car is lowered just a bit to clear the Gap and I have 205/40/17 they fit just PERFECT and on dips and bumps I doesn't hit the fenders.
You will probably need to go with the 205/40 or 205/45 if you are not planing on lowering
ballplaya4eva07
May 26, 2005 06:28 AM
fastman90
Apr 22, 2005 03:23 PM
INJENalltheway
Dec 28, 2004 08:06 PM
jablalock06
Nov 19, 2004 04:05 PM
zaidomar
Nov 17, 2004 01:06 PM
