TPMS light wont go off
Old Jun 10, 2017 | 04:55 PM
Flygirl's Avatar
Default TPMS light wont go off
Hi
I have a 2012 civic hybrid. Recently the TPMS (tire pressure monitor system) light went on. I checked the tire pressure in all tires and they are fine. Why is the light still on, and what could be causing this/ Is it something serious? Any help would be greatly appreciated. Thx!
Old Jun 11, 2017 | 12:21 PM
Duane4238's Avatar
If you have a compressor handy, you might try dropping the air pressure in each tire by about 5 psi, and then airing them back up to where they should be. Also be aware that your tpms will not react immediately to changes in pressure. Sometimes it can take up to 50 miles of driving before it reacts. I'm not sure if there is a tpms sensor in the spare tire in the trunk, but you might check that just to be sure it's OK.
Duane
Old Jun 11, 2017 | 02:34 PM
Flygirl's Avatar
Default Tpms
Thank you so much for responding. I will try your suggestion!
Old Jun 14, 2017 | 06:21 PM
Duane4238's Avatar
So, did the light go out? If not, stop at an Autozone or O'reilly's and see if they can reset it. If they can't, try a local tire dealer. They all have the handheld scanner for resetting the tpms. Don't go to the dealer. They'll charge you an arm and a leg. It only takes about 5 minutes to scan and reset all 4 tire monitors.
Duane
DaCapitan
Jul 14, 2012 12:33 AM
RRB
Dec 29, 2008 03:30 PM
08CCSI
Aug 12, 2008 02:26 AM
tjbarne
Apr 26, 2008 09:08 PM
coolaznboi112
Mar 21, 2008 06:27 PM
