TPS
Old Feb 14, 2008 | 11:35 AM
hondaT's Avatar
Default TPS
will i need to use a multi-meter to set my throttle position sensor when i replace it??
Old Feb 14, 2008 | 12:01 PM
Default RE: TPS
What year Civic? I believe the TPS is part of the throttle body and does not require calibration.
Old Feb 14, 2008 | 05:03 PM
hondaT's Avatar
Default RE: TPS
1991
Old Feb 14, 2008 | 05:10 PM
Default RE: TPS
You're supposed to replace the whole throttle body with TPS attached. They set them up at the factory and attach it with breakaway screws.
You can drill out the screws and replace the TPS only but then you would have to calibrate it with a meter.
Old Feb 15, 2008 | 05:30 AM
Default RE: TPS
There are a couple companies out now that are selling just the TPS sensors, and they're pretty easy to replace/calibrate. Buying the entire throttle body just to replace a <$50 sensor is just retarded.
You'll need to use a multimeter. Tap into the middle wire on the TPS and get your readings from there. You'll need to be between .45 & .50 at Closed throttle, and 4.5 & 5.0 at WOT.
Old Feb 15, 2008 | 06:34 AM
Default RE: TPS
ORIGINAL: Forty04
Good to know. Thanks for the update on the TPS sensor.
ksorce
May 15, 2006 09:08 AM
top99sir
Mar 26, 2006 07:37 AM
ef4life
ED-EF Swaps
16
Jan 25, 2006 04:51 PM
cmasonrun
Jan 12, 2006 11:25 PM
fast93civic
Jun 11, 2005 10:19 PM
