tps sensor help
Old Apr 14, 2011 | 02:27 PM
cjy01's Avatar
Default tps sensor help
so my car has been reving up and down and back firing. i got some carb cleaner and sprayed around the tps sensor and it tried to cut off. could this be the problem
Old Apr 14, 2011 | 05:36 PM
Backfiring usually means the timing is way wrong. You should check if the timing belt has skipped.
Old Apr 14, 2011 | 08:01 PM
JdmTechOps's Avatar
had same problem man its mostly timing remeber backfiring = timing
TIcivic00
Sep 7, 2007 07:27 AM
glada96EX
Aug 6, 2006 11:18 AM
patcheway
May 30, 2006 03:29 PM
ef4life
ED-EF Swaps
16
Jan 25, 2006 04:51 PM
fast93civic
Jun 11, 2005 10:19 PM
