Transmission??
Old Jan 2, 2007 | 06:41 PM
02civicex2dr's Avatar
Default Transmission??
Hi Folks,
Happy new year! Have an 02 Civic EXautomatic with 70k. Tranny fluid level is OK and fluid was just changedby a Honda dealer.
When the engine is cold (temperature doesn't have to be -10 cold, lets say 25) the tranny seems to surge (slip?) right after it shifts. It shifts, and the RPM's build for a quick second after then drop. It seems to happen before it goes into OD.It stops doing this after several minutes (miles?) after the car is warmed up, but seems to do this every time its cold.
I know transmissions usually rev higher when they are cool, but not even on a derilect Taurus have I seen such actions!
The second question I have - is when you turn right (I think?) and give it gas, the transmission is fairlyjerks. It only seems to do this when you turn right.
Thank you very much!
- A puzzled Honda owner
Old Jan 2, 2007 | 06:56 PM
Default RE: Transmission??
I guess you could describe the jerk as almost a shudder when you give it gas - its usually after the tranny goes up a gear (slower speeds)
Old Jan 3, 2007 | 05:32 PM
Called up dealer........said would cost over 50 dollars to check into problem.........the car is Honda certified, any warranty relief for the test?
Old Jan 7, 2007 | 06:49 PM
Anybody have any advice ?
Old Jan 7, 2007 | 10:21 PM
CivicSiSolja's Avatar
most of us drive mannys but im sure someone has an answer ....bump it for ya
Old Jan 9, 2007 | 07:48 PM
Thanks....the cold weather is wisconsin was making it act up a fair amount today - after the engine cools for 30-45 minutes, it will "flare" up after it shifts......until it gets "warm".......
mxer518
Mar 19, 2005 02:49 PM
slideman99
Aug 3, 2004 06:10 PM
ZCJDMCIVIC
Aug 3, 2004 05:35 PM
Civic95Blue
Jul 29, 2004 10:09 PM
NYC Civic
Jun 18, 2004 03:46 PM
