Transmission down shifting.
Old May 18, 2008 | 11:01 PM
TheJGB3's Avatar
Default RE: Transmission down shifting.
You usea 3/8" ratchet (the square part) to remove the drain plug. About 2.5qts will drain out. Then top it off - USE ONLY HONDA OEM ATF-Z1 FLUID. If you don't, you will be replacing the trans very soon (due to failure) because all non-Honda trans fluidshave incorrect friction modifiers for a Honda trans. After topping it off, start the car and go through all of the gears. Then shut it off and remove the drain plug and drain again. After draining the 2nd time, top it off again with OEM ATF-Z1.
MrSamNC
Feb 25, 2014 12:37 PM
queenlowla
Jul 31, 2013 06:18 PM
sparmar
Mar 21, 2010 05:32 AM
clownbaby
Aug 31, 2009 02:06 PM
Esquirrel
19
Aug 14, 2005 11:16 AM
