Transmission noise affected by clutch
Old Mar 31, 2006 | 10:21 PM
campbuds's Avatar
Default Transmission noise affected by clutch
I get a loud bearing type noise when the clutch is engaged. (even while in nuetral) It goes away when the clutch pedal is pressed. I was told it was for sure the throw out bearing. Well I put a whole new clutch kit in the vehicle and it is as loud as ever.
Any ideas?
Old Apr 1, 2006 | 10:28 AM
joey's Avatar
Default RE: Transmission noise affected by clutch
well it seems you just replaced your clutch for nothing....the noise is caused by a bearing in your tranny, not the throwout bearing but i can't remember the name of it...i've had 2 91 civics that made the same noise, including the one i drive now. i just live with it. it doesn't seem to affect driveability.
Old Apr 1, 2006 | 12:00 PM
campbuds's Avatar
Well mine is REALLY loud. The noise is noticeable to others outside the car.
The clutch needed replaced anyway. It was pretty much at the end of it's life as well as the trhow out bearing and pilot bearing. But now I need to find a used tranny in good condition.
Old Apr 1, 2006 | 03:36 PM
joey's Avatar
yea mine's the same way... gets louder/faster when i drive....i assume over time it'll get bad enuf that the car won't be driveable but i'm hoping it takes a while.... after some research i believe the bearing in question is the input shaft bearing.... its a common weakness. don't know how hard it is to replace or how much it would cost....at least used civic trannys are easy to come by and also inexpensive.
Old Apr 1, 2006 | 09:56 PM
Kappa22's Avatar
Sounds like the input shaft bearing.
Old Apr 2, 2006 | 12:48 AM
01CivicEX's Avatar
yeah prob input shaft i had the same problem a month ago, had it replaced and now its perfect
Old Apr 2, 2006 | 08:43 AM
Stimpy's Avatar
crud.
I have the same problem and I've been assuming its just the throwout bearing. how much did it cost you to get it fixed?
Old Apr 2, 2006 | 12:06 PM
joey's Avatar
if its not replaced, will it eventually put my car out of commission or is it one of those thigns ya can basically drive on forever.
Old Apr 3, 2006 | 04:53 PM
akskimaster's Avatar
ORIGINAL: Stimpy
crud.
I have always heard it was the throwout bearing as well.
Old Apr 3, 2006 | 04:57 PM
ef4life's Avatar
yeah it is most likely the input shaft bearing, but if the tranny is off you might as well replace the throwout bearing too. for an O.E. one from honda it is like 40 bucks
civicminded02
Aug 10, 2014 04:03 AM
redraif
Mar 7, 2013 01:59 PM
bakertime
Jan 12, 2007 07:25 AM
karney
Jul 31, 2006 04:23 PM
silverspring71
Sep 7, 2005 04:42 AM
