Trouble Code P1382 'Cylinder Position sensor no signal'
My car's check engine light came on. I took it to AutoZone to get a code. The code is P1382 '
no signal' is written of the diagnoses paper they printed.
Symptoms are the car will shut off when I come to a stop if not in neutral. It idles very low and has some power issues. It also shuts off as the engine warms up and misfires while running.
Where is the ' '?
Thanks
Where is the ' '?
Thanks
1996 to 2000 model it is on the bottom of the engine at the crank pulley. Common for the sensor's wires to get caught in the pulley or belts and get cut.
Not idling you should clean the IACV. Also check the spark timing. The sensor doesn't cause those problems, it pretty much just turns the CEL on if the timing belt has skipped.
