Code P1381 cylinder position
Old Aug 4, 2009 | 10:01 AM
choadtx's Avatar
Default Code P1381 cylinder position
I having the CEL light on and the code is P1381. From what I could find, I need to change my crank position sensor. Is this where it is?
Plugs in where the top arrow is... Goes to the bottom of the engine sensor bolts in there?
Any help is appreciated...
Old Aug 4, 2009 | 10:02 AM
choadtx's Avatar
Oh, 1996 Civic DX. I have reset the light and it keeps coming back...
Old Apr 6, 2011 | 06:40 PM
Honda6450's Avatar
p1381 is in the lil yellow wire in your distributor my friend this i know.. i replaced my timing belt and crank shaft pos. sensor n had the same code..this is when your car gets hot n shuts off automatically n wont start till it cools down.
Old Apr 6, 2011 | 06:44 PM
Like the other guy said, the CYP is inside the distributor. The sensor on the crankshaft is the CKF sensor. The 1996 system still uses the distributor for all spark and injection timing. The crank sensor is used only to detect a skipped timing belt.
lindylex
Apr 21, 2015 08:38 PM
George4242
Nov 19, 2011 06:17 AM
90hatch12167
Apr 19, 2010 04:28 AM
Red_Neck
Mar 22, 2007 12:35 PM
