Trouble With MAP Sensor
Old Mar 12, 2005 | 06:47 PM
scooterspeed's Avatar
Default Trouble With MAP Sensor
I recently purchased a 97 Civic DX with the Check Engine Light on. The OBD II Code reader said it was because the Manifold Absolute Pressure (map) sensor was receiving high input - P0108. I replaced the sensor and I am still getting the code. The engine is running sluggish at low speeds. You can definately tell a loss of HP. I am wondering if anyone else has had this problem or might know what to look at. Thanks - Scooter
Old Mar 12, 2005 | 07:28 PM
rzimmer11's Avatar
Default RE: Trouble With MAP Sensor
Check your Oxygen Senser which on your motor should go right into the bottom of your headers and is visible from the front of the car.
00sithrottle
May 12, 2005 10:25 AM
00sithrottle
May 11, 2005 10:18 AM
firzout
Apr 8, 2005 11:22 AM
red_sleeper
Jan 15, 2005 01:08 AM
