turn signal issues
I own a 2001 ex, i got it used with aftermarket headlights already installed but damaged. I replaced them and plugged in the new one and now when i turn my headlights on the left turn signal is stuck as if it were flashing even when i dont have the lever pulled. the hazards work fine and when the lights are not on the signals work but when i turn the **** the light comes on in the dash indicating my left turn signal is on(but it doesn't blink just constantly on). Can somone help
the ground to the marker light goes into a wire harness but i did notice the signal light in the rear is on also, i was told it could be the signal relay i will pull it and test it to see if hats the problem, thanks a milli
marcosv827
Aug 8, 2005 05:58 PM
burnoutNshootnos
Dec 22, 2004 10:30 PM
