two problems
Old Dec 31, 2004 | 02:02 PM
kevin121987's Avatar
Default two problems
first engine light on.. code 5 map sensor.. changed it.. changed computer.. checked all wiring and ohms are dead on.. voltage dead on.. light will not clear.. changed computer light still on.. runs fine.. just will not get light out.. car was hard to start.. when other computer was put on.. it start easy.. but.. has bad hesitation at early throttle.. like just taking off.. or trying to go very slow.. 15 miles per hour or less.. when throttle is barely pushed.. cuts out.. like fuel is shut off.. but if you keep your foot there at same place it will catch again and go then cut out again.. push throttle in more and it comes alive and drives great.. but it seems i am only getting around 25 miles to the gallon too.. any one out there got any clue to what the heck is going on??????
Old Jan 4, 2005 | 10:42 PM
fast97's Avatar
Default RE: two problems
reset yur computer dissconnect the battery for a bout fiv minutes.
Old Jan 5, 2005 | 11:24 PM
nwhite82's Avatar
do you have a dead spot in your throttle cable? that wouldnt make your light come on though.
NIKE H34D
Sep 2, 2012 01:17 PM
Lightsped
Aug 28, 2008 10:06 AM
b0bcatt34
Jun 9, 2006 10:11 PM
fast93civic
Apr 25, 2005 02:00 PM
Mad7s
Dec 15, 2004 09:01 PM
