Two Spun bearings help
2001 honda civic black 155xxx miles.
Always had my car serviced on time. This time it must of had a leak It still had two thousand more miles left till its next oil changed and there was none and I had no clue till I got a knock in my engine. So I got it home towed it too the garage.
Dropped the oil pan took out all the bearings main and rod.
Two bearings were spun rod 1 and 4 or maybe 2 and 4 can't remember.
The crank has a micro scratch on it where the first bearing spun. I'm thinking that you could almost polish it with your finger and a small pad or maybe even sand it lightly.
You think its safe to just replace the bearings?
Where Can I get a set of main and rod bearings with oil pan gasket? Can I order these parts from my local Honda dealer? Thanks guys.
You might beable to clean the crank up. But be real easy on it. For the bearings you can only get them from honda. If you know what you are looking for you can go to http://www.hondaautomotiveparts.com/
I agree 100% with Wellfedhobo. That is the correct way to do it. But if that is out of your price range you might be able to clean it up by hand like i said before. But you could end up with another set of bad bearings. The crank is deff not an area you want to go cheap on.
I just need it to make it 10 miles to the dealer without spinning another one anyone know the colors I need? I'm not sure what color bearings I need or how to look.
I'd be very grateful for anyone who could answer ordering the parts tomorrow.
1.7L Non-vtech em2 coup 2001 LX
Yes I'm trading it but only too the stealership so its not like they wont get more out of it fixing it right for less.
NIKE H34D
Sep 2, 2012 01:17 PM
thakid
Dec 14, 2011 01:48 PM
