Typical rear wheel well rust.
Old Oct 8, 2007 | 06:41 PM
dittoalex's Avatar
Default Typical rear wheel well rust.
Can this be DIY in the garage? Remove rust, bondo, sand, paint? How easy is it?
How much do body shops usually charge?
Old Oct 9, 2007 | 08:28 AM
kinosh's Avatar
Default RE: Typical rear wheel well rust.
I had a body shop do it for $1,500 (both sides). Mine was bad enough where it did not pass the annual inspection. The shop sandblasted the rust off, then welded metal to fill the void. They did a good job and it took 5 days.
Old Oct 9, 2007 | 03:14 PM
foress_89's Avatar
In your own garage it won't look good.. unless you know what you're doing. Like it's just been said, you need to weld new panels over the holes, and then smooth it out with bondo, you must not fill the holes with bondo, it won't look good.
Old Oct 9, 2007 | 05:54 PM
dittoalex's Avatar
I'm not concerned with it looking good. The car's a beater.
Would it stop the rust from spreading?
Paint'll be easy, car's black.
Old Oct 9, 2007 | 06:03 PM
GReddy_Civic's Avatar
Snail'n Admin
well if you dont care what it looks like then yea that should work. However, if you are gonna sand it and bondo it, it still is gonna take a while to even get itlooking half decent. Body work is very time consuming even if you know what you're doing
Old Oct 9, 2007 | 06:07 PM
dittoalex's Avatar
Maaco?
Old Oct 10, 2007 | 07:41 PM
Snail'n Admin
they do really crappy work but like u said, u dont care so go for it
GDizzle2
Jul 13, 2010 05:30 AM
cbaber
Jan 17, 2008 12:26 PM
Dustin
Mar 9, 2007 12:21 AM
Seafoamgreencivic
Jan 3, 2006 05:24 PM
larsenracing
Dec 22, 2005 09:50 AM
