urrrggghhh
driving down the eway this morning and all of a sudden with no warning lost power, pulled over tried starting, no resistance from engine, new starter, alt and dist. assy. any ideas, also no clattering noise when it stopped running
Check whether the timing belt snapped. Take off the oil cap from the valve cover and, while a buddy cranks the engine, use a flashlight to see whether the camshaft turns. Turning of crank pulley but not camshaft indicates a broken timing belt.
dont know car is still on the eway cant get to it till tomorrow, the screw problem was on my old dist. didnt have my tool set with me to check it tried to get the timing cover off with me leatherman multi tool, no way!!! needed my wrenches
What year Civic?
If luck is with you and the timing belt is fine, then be prepared to check for spark at the plugs and priming of the fuel pump. No spark would likely mean a bad coil or igniter unit in the distributor, wheres no fuel pump priming could suggest a bad main relay.
If you have both spark and pump priming, then the timing belt may have skipped some teeth. You'll need to get the car off the freeway to check for this possibility.
