using oil!
Old Feb 24, 2006 | 07:56 AM
larsenracing's Avatar
Default using oil!
My 98' civic ex is using alot of oil like 1qt. per 200 miles or so. Could it be the valve seals? what is your thoughts, thanks.
Old Feb 24, 2006 | 08:21 AM
Sphinx_1's Avatar
Default RE: using oil!
Is it smoking? if the valve seals are leaking the car will smoke. If its not smoking when you start it or under acceleration then you might have other problems. It also might be your Rings.
Old Feb 24, 2006 | 02:39 PM
Yes it does smoke but not that bad i dont think it really smokes bad enough to loose that much oil but who knows also it bascly seems like it just showed up one day al the suddon i mean with in like 1,500 miles. But it does run pretty well, the only problem is that it doesnt start very well when it is less than 10 deg.
Old Feb 24, 2006 | 06:20 PM
natecivic92's Avatar
ARe you sure i isnt leaking oil.
Old Feb 25, 2006 | 12:13 AM
Sphinx_1's Avatar
I have to crank mine a little bit when it is cold out.. Also check to make sure you dont have a bad oil leak. Check the pan gasket to see if it is leaking...Just check out the engine real good for leaks.
Old Feb 25, 2006 | 12:40 AM
Pete's Avatar
Before u change the oil you can put some Dye in it, and then hit it with a black light, it shows where its coming from. Be sure to drain that crap and refill with good oil thou
Old Feb 25, 2006 | 01:49 AM
Kappa22's Avatar
Bad rings are a more common cause of oil loss than valve seals.
vwcivic
Jun 25, 2012 02:53 PM
project94
Mar 21, 2012 08:05 PM
planes77ca
Nov 29, 2010 06:17 PM
oilltd
Jun 10, 2008 04:06 PM
