Valve Cover Bolt
Old Sep 21, 2010 | 06:11 PM
DanoATX's Avatar
Exclamation Valve Cover Bolt
SO i overtightened the number 3 bolt on my valve cover. The screw basically broke off in the hole. Am i screwed? has this ever happened before? is there a tool i can fish down in there to get the threaded part out? Please help. 97' civic ex 1.6 liter sohc v-tec, How do i get that broke off screw out ? i can pull the bolt out but i broke offf the little part on the end that screws in. How di i get that part out. please tell me there is a way.
Old Sep 21, 2010 | 08:33 PM
silver2000civic's Avatar
Buy an easy out kit. They come with right hand drill bits and a extractor.
http://buy1.snapon.com/catalog/item....&group_ID=1254
This is is the set i have. But you can go to sears and pick them up or autozone.
Old Sep 22, 2010 | 06:01 AM
DanoATX's Avatar
Thumbs up
This will help for sure, Thx
Old Sep 22, 2010 | 06:08 AM
I don't remember how those are built, I think the bolt goes all the way through the rocker assembly into the head. In that case removing the rocker assembly may expose enough of the broken bolt to grab onto it. To remove the rockers take all the bolts out and lift it off as a unit. It will stay together in one piece as long as you don't pull on the ends.
Before working inside the valve cover, stop up the oil return holes with rags. Or you will drop something down there and it will land in the oil pan.
Old Jul 2, 2012 | 06:19 PM
kghCivic's Avatar
I did the same thing, i used a drill extractor to get it out, and it worked perfect. Does anyone know where i can get a replacement bolt?
Old Jul 3, 2012 | 07:05 AM
Replacement SOHC valve cover bolts? I would just go to Honda and get them. If you are hurting for cash, try hondapartsdeals.com.
Blackkat911
Jul 12, 2008 03:40 PM
saiguanas
Jul 6, 2008 08:40 PM
crazybolts
Jun 21, 2007 12:52 AM
99dx
Jun 17, 2007 09:08 PM
mill$civic
Oct 31, 2005 06:25 PM
