voltage drop
Old Feb 18, 2009 | 07:15 PM
tekkery2k's Avatar
Unhappy voltage drop
Has anyone ever had a voltage drop in their '02 Civic. I just bought a new battery. As soon as I turn on the a/c, rear defroster, stereo system, and headlights, the voltage drops to 12.5V when on and the belts screech. The belts will only screech once, and won't do it again, and the volatge will go back up to 14.32V
Old Feb 18, 2009 | 07:16 PM
Try tightening the alternator belt.
Old Feb 19, 2009 | 05:59 AM
After the belt is tightened or replaced so it doesn't screech, still expect some voltage drop at idle with everything on. If you have large amplifiers in the stereo system and require full performance at idle, consider installing a high-output alternator.
Old Feb 19, 2009 | 10:37 AM
^ x3
and check your battery terminals... if the wires are corroded or dirty clean them get all that corrosion off the terminals. and have your alternator tested out at autozone with it on the car. it might be getting weak.
addiction2bass
22
Jun 21, 2007 08:16 AM
Motor35
Oct 6, 2006 11:13 PM
pacman
Feb 12, 2006 12:03 AM
punchodex
Nov 14, 2005 08:11 PM
02CivicEX
Mar 6, 2005 10:45 AM
