VTEC
Old Apr 30, 2008 | 01:14 PM
chandler583's Avatar
Default VTEC
OK, I am sure this has been asked many, many times before, but is there a quick and easy way to check if a car has VTEC? It is a 1998 EX with a VTEC tuning decal on the trunk, but the motor has been replaced since then because the previous owner dogged it to death. I did not do the engine replacement, because I did not own it at the time, I am the third owner of this car.
Old Apr 30, 2008 | 06:03 PM
mundy5's Avatar
Default RE: VTEC
i believe if it is a vtec, it says it right on the top of the engine.
Old Apr 30, 2008 | 06:05 PM
mundy5's Avatar
Default RE: VTEC
check out this picture and you'll see vtec right on it. this is off a 2000 si but it should be very similar
http://rides.webshots.com/photo/1047...34003352nuouLO
Old Apr 30, 2008 | 08:42 PM
Default RE: VTEC
ORIGINAL: mundy5
not always
check this out
Old Apr 30, 2008 | 09:19 PM
croninc's Avatar
Default RE: VTEC
well it will not always say vtec on it if it has vtec, so like my car a 99 civic ex it has vtec because its an ex. So if they guy before put the same stock engine back in then we would know its vtec. take a pic of the engine and post it or ask they guy what engine he put in. btw i would take off the vtec stick on the truck....kinda dumb
Old May 1, 2008 | 02:41 PM
Default RE: VTEC
The VTEC looks kind of cool because it looks like it came from the factory like that... The lady we bought it from did not know much about cars...Took it to walmart for maintenance. It leaks a little oil, because they overfilled it with oil and built too much pressure in the engine and messed up some seals and gaskets, it only leaks when the engine is hot.
Well, my engine looks alot like the engine in the sticky pic, without the funny air intake... I looked in that spot and it says B16Y8.... The tranny VIN matches the car VIN, could that be the original transmission?
[IMG]local://upfiles/30764/1CCA5CB22F224B0E93CF5C704854CAC5.jpg[/IMG]
[IMG]local://upfiles/30764/CD8304F4C88D406CA74E07086A53825F.jpg[/IMG]
Old May 1, 2008 | 03:15 PM
Rmpge15's Avatar
Default RE: VTEC
I think you mean d16y8 which in case it would have a v-tec
Old May 1, 2008 | 03:18 PM
Default RE: VTEC
It most likely is, the engine bay has not been cleaned good and I had to wipe old oil from the plate to see... Does anyone know at what RPM does VTEC engage on this engine?
Old May 1, 2008 | 03:21 PM
Rmpge15's Avatar
Default RE: VTEC
5400 rpm
Booger
EK Swaps
Aug 9, 2011 10:11 PM
88civicjordan
Mar 2, 2006 09:12 PM
ryantann
Feb 21, 2006 09:50 PM
mahmi
Aug 25, 2005 09:39 AM
kcmercedes
EK Swaps
Sep 24, 2004 11:05 PM
