Vtec Issue
Old May 24, 2008 | 11:00 PM
falkirkfc5's Avatar
Default Vtec Issue
Hi all,
I hope that this is the the right place for this (sorry if not) - i have bought a 95 hatchback civic the split boot one.... on the log book it states it has a D16Z6 vtec engine in it, but i have checked the engine and it says D15Z3 the VTEC-E engine. when i asked the previous owner he said he go it with that engine in it....... But the problem i have is when i sink my foot and reach that magial RPM it begins to hit what i could descride as a limiter for the vtec to kick in i have to lift off the gas and then accelarate again, i have also tried progressively accelarated to the 5500 rpm and the vtec kicks in fine with a slight hessitation.
Can anyone help me in this situation........ i am not really clued up on the vtec system- i am getting a haynes manual to help me hopefully......(i know haynes is sad but i need to)
Hope u's can help- speak to u all soon
Paul
Old May 25, 2008 | 06:35 AM
Default RE: Vtec Issue
Is the CEL ON?
http://www.honda-tech.com/zerothread/1901557
Old May 25, 2008 | 07:12 AM
When whoever put that engine in it, they probably forgot to put in the correct ECU. I talked to a guy before who had blown his engine and swapped in a d15z1, but forgot to swap the ECU and the car did what you are talking about.
D16Z6 uses a P28 ECU. If that's what you have then you have the wrong ECU for the D15Z3.
I think you're supposed to have a P07 ECU. That's what the D15Z1 uses and they're both VTEC-E so it should be right. Are you out of the USA? because that's not a USDM engine, it's from a Vti.
If it's the wrong one and you need to replace it make sure you get an ECU that matches your transmission. The manual ECU is different from the automatic one.
Old May 25, 2008 | 10:34 AM
civic_burns_all's Avatar
yep seems like the car needs a good ECU tune
Old May 26, 2008 | 01:15 AM
falkirkfc5's Avatar
As you guessed im not from the usa, im from scotland, UK.
i have checked the ecu and the on that is in the car is a P28 so im now gonna source a P07 ecu, will keep u's posted on what happens
cheers for the advice
mudhenFUF
Jan 16, 2023 08:43 PM
Booger
EK Swaps
Aug 9, 2011 10:11 PM
soon2bsick
Feb 6, 2011 11:50 AM
Civics4Life
Nov 6, 2009 09:43 PM
