Weather dependent Car condition?
Old Feb 11, 2008 | 02:52 PM
jbum's Avatar
Default Weather dependent Car condition?
I'm a newbie to engines and this is a general questions regarding my observations of my '93 Civic DX.
On cold days, I notice that when I start the car and drive the car sounds and feels a bit rought. The engine is louder and the clutch sounds sounds squeakier (it's about time to change the clutch btw).
On warm days, the engine is quiet and smoother. The car seems peppier too. I guess the car is old and can use some TLC.
Things like the bushings, vacuum hoses, etc. could all be refreshed along with a new clutch.
Just wondering if I'm imagining this or there is some truth to the weather dependent behavior I'm seeing...
Thanks!
Old Feb 11, 2008 | 02:58 PM
Default RE: Weather dependent Car condition?
You might have a faulty fast idle valve.
Old Feb 11, 2008 | 03:20 PM
jbum's Avatar
doesn't that valve adjust the air intake when the engine is warm? the engine rpm comes down to normal after the engine has heated up. could it still be faulty?
Old Feb 11, 2008 | 03:50 PM
Opposite. The fast idle valve controls the idle when the engine is cold.
Old Feb 11, 2008 | 05:43 PM
jbum's Avatar
sorry that's what i meant.... when the engine is warm, the fast idle valve should close and the engine should not be reving high. so it appears to be working
Old Feb 11, 2008 | 07:49 PM
JimBlake's Avatar
Cold influencesa lot of things.
Thicker oil = more drag for the engine. It's working harder just to stay running. That should become normal as the engine warms up.
Cold engine = fuel doesn't vaporize as well, not as much power. That should also become normal as theengine warms up.
Does this stuff continue even after the engine's at normal operating temperature?
Does it take forever to reach normal operating temperature? If so, you may have a stuck-open thermostat.
The oil in the shock absorbers also warms up with motion. When real cold they're more stiff. That contributes to a general feeling of harshness.
Old Feb 12, 2008 | 05:50 AM
ORIGINAL: jbum
Please disregard my responses as I misread your original post.
Old Feb 12, 2008 | 10:09 AM
jbum's Avatar
ORIGINAL: JimBlake
Thanks, I think everything you said is probably contributing to the sensation I get during a cold day.
My thermostat is probably stuck open... it takes forever to warm up... actually, if I'm driving at relatively high speeds, it never comes up to even a 1/3 of the way. Only when I go through stop and go traffic does the needle come up.
Old Feb 12, 2008 | 07:09 PM
JimBlake's Avatar
If the engine stays colder than the proper operating temperature, then the ECU gives extra gasoline because it "thinks" it needs to (based on the coolant-temperature sensor).
Get a new thermostat. Need an excuse to change anti-freeze? It loses it's anti-corrosion properties after a couple years - and you can't measure that with a float-hydrometer.
As long as we're talking about fluid lifespan, brake fluid should also be replaced every couple years too. But that's probably not part of the stuff you're complaining about in the first post.
bwoso
Jul 28, 2009 09:02 PM
rockyrhoda
Sep 20, 2007 04:00 PM
Bananaboat11
Sep 8, 2007 07:37 AM
incogneato
Aug 7, 2007 12:30 PM
wrinkledpants
Dec 3, 2006 10:30 PM
