what to clean inside of valve cover with
hi,
so i have decided to clean the inside of my valve cover and judging by the caked oil on it the previous owner never did this.
my question is what should i clean it with? i am worried that if i clean it with some chemical that some of it will remain in the valve cover (in some nook or cranny) and get in the engine when i put it back on and ruin something in the engine.
does anyone have any suggestions that wouldn't harm the engine?
would flushing the valve cover with water after i clean it prevent the chemicals from damaging the engine?
I have always just used degreaser and/or brake clean and wiped it all clean. Afterwards, I run the VC under water to make sure everything is out and let it sit outside in the sun to dry prior to reinstalling.
Yeah I would just use a degreaser. You might not use 1/2 a can even..but you may want to degrease a certain part of your engine with the remaining degreaser later.
With the underside of the Valve cover..just scrub with a brush & see that black/brown turn into a nice silvery shine again...Then spray with water.
Repeat if you missed any spots(the corners get tricky).
addiction2bass
Oct 9, 2009 03:25 PM
blk04cleancivic
Feb 4, 2008 08:51 AM
mill$civic
Oct 31, 2005 06:25 PM
Forty04
Jul 11, 2005 08:24 AM
dalifts
Sep 13, 2004 03:33 PM
