What is this part???
Old Aug 2, 2008 | 10:31 PM
azhondarider's Avatar
Default What is this part???
So my brother took the fuel hose off of the fuel rail on his 94 civic with the 1.6 motor and there is this wierd piece that screws onto the end of the fuel rail that holds the fuel hose on. What the hell is this piece? I have taken it to autozone and checker and they have no clue. I need a new one but dont know what it its called or what it does. Anyone know what it is?
Old Aug 2, 2008 | 10:52 PM
SilverSedan's Avatar
you got a picture of this mystery piece?
Old Aug 3, 2008 | 05:40 AM
hes talking about this i believe.... but then again i have no idea what it does either.
i dont think it does anything... i could be wrong tho.
Old Aug 3, 2008 | 09:31 AM
Yes that is the part. Anyone know what it is called?
Old Aug 3, 2008 | 09:42 AM
I think the fix may involve purchasing an entire fuel rail:
http://www.hondaautomotiveparts.com/...NTAKE+MANIFOLD
You might also look for a used replacement at a local salvage yard.
Old Aug 3, 2008 | 09:55 AM
That is the pulsation dampener. It has a diaphragm and spring to keep the fuel pressure from pulsating much as the injectors open and close. Going to be a dealer part, or since they very rarely go bad, get one from a parts car.
Old Aug 3, 2008 | 10:10 AM
Thanks for the info. it didnt go bad but the threads are jacked up and allowing it to leak. thanks everyone
Old Aug 3, 2008 | 10:17 AM
You may need the fuel rail too then, since it's steel versus aluminum there. Also you must have exactly one copper washer in place on each side of the "banjo" fitting on the fuel line.
Old Aug 3, 2008 | 10:20 AM
yes thanks thats what started this whole problem in the first place. any idea where I can get those washers?
Old Aug 3, 2008 | 11:40 AM
try autozone.... they should be a rather common copper washer... they should have extra ones for sale. your suposed to replace them with any high pressure line. like brakes and fuel.
halfpower
Mar 22, 2009 12:28 AM
Braidon5407
Jan 17, 2008 05:35 AM
Colby Day
13
Oct 1, 2006 10:10 PM
streethonda95
May 3, 2005 08:39 PM
song213
Feb 13, 2005 01:08 PM
