What is this switch
Old Jul 13, 2009 | 05:24 PM
hamorhead's Avatar
could the switch be for the fogs?
just an idea...
have you tried flipping it into the opposite side than its been on and see what does or doesn't work?
^last time i did that i found an ignition kill from a previous owner lol
Old Jul 13, 2009 | 05:33 PM
neo1piv14's Avatar
just an idea...
I'm not sure. The electronics in my car are a little whacked out. I just lost all my cluster lights and climate control lights last night, so I've got a bit of work ahead of me. I have tried toggling that switch without any noticeable effect to anything. That PIAA relay only fits one way, but I did hear it making a clicking sort of noise when I fired up the flashers.
Old Jul 13, 2009 | 05:51 PM
Originally Posted by neo1piv14
...I just lost all my cluster lights and climate control lights last night, so I've got a bit of work ahead of me.
Check whether fuse 19 under the dash is blown. If not, the dimmer switch may be bad.
Old Jul 13, 2009 | 09:16 PM
Sigracer10's Avatar
that switch looks about identical to the switches that come with the remote start systems at my work. are there 2 wires coming out that are black/white?
Old Jul 13, 2009 | 09:35 PM
danomatic93's Avatar
June 2010 ROTM
that would make sense.
Old Jul 13, 2009 | 10:15 PM
Does the alarm he installed have remote start?
That is the same exact switch that came with my Viper remote start and it is to be used as a switch that when it is turned off, the remote start will not work even when you press the correct sequence of buttons on the key fob, and when turned on it will allow remote start to work normally.
Old Jul 14, 2009 | 05:15 AM
neo1piv14's Avatar
I'd be really surprised if he installed a remote start. The remote only has one button, and that just toggles between lock/unlock. As far as my lighting goes, I think it might just be the switch I use to turn them on. I got pulled over last night because my tail lights weren't on. However, they came on when I hit my brakes, flashers, and made my alarm flash all my lights (which also makes all my interior lights flash). So I'm not thinking it's a blown fuse, since the lights are all working, just not being activated by that rotary switch on my steering column.
Old Jul 14, 2009 | 05:39 AM
Hazard and brake lights are different from the taillights -- check fuse 19 and the ground wire in the rear.
Old Jul 14, 2009 | 06:06 AM
neo1piv14's Avatar
I'll give that a try this evening. Thanks man!
Yep. It works just fine now. Thanks!
danomatic93
Routine Maintenance DIYs
Jan 15, 2012 07:16 AM
AggressiveAdam
14
Sep 27, 2007 07:02 PM
2000Ex
Jun 14, 2005 04:59 PM
cojodough
Apr 17, 2005 03:02 AM
zeppelinfire05
Sep 1, 2004 02:38 PM
