What would cause this? (Timing Question)
Old Jul 12, 2010 | 06:58 PM
Dannicus's Avatar
Default What would cause this? (Timing Question)
I went to check my timing and it was maybe twice as far from TDC as it specs in the FSM and it took all of the distributer travel to get the red tab ALMOST to the reference tab. Something's gotta be amiss. Any thoughts?
Old Jul 12, 2010 | 07:36 PM
The mechanical timing is off by one tooth on the timing belt. If the belt is old, it may have slipped so replace it and set the mechanical timing correctly.
Old Jul 12, 2010 | 08:28 PM
Dannicus's Avatar
It's amazing that it runs so well and I'm thankful it didn't slip into interference.
I took another look at it with the upper timing belt cover off. If I shine the timing light at the cam pulley, the TDC mark is actually rotated past TDC with the crank pulley timing mark nearly at the indicator.
Wow, I guess it's good timing that I just got my timing belt job parts together!
Old Jul 12, 2010 | 10:54 PM
civicalized's Avatar
Default slip?
Hi, I'm wondering if it's more likely the belt slipped or was incorrectly installed. I'd always assumed that rubber timing belts don't slip. Anyone with experience with this?
Old Aug 9, 2010 | 05:24 PM
Dannicus's Avatar
Replaced the timing belt, quadruple checked the alignment, and the timing is still off. WTF? I need a differential diagnosis.
Old Aug 9, 2010 | 06:12 PM
Check cam timing (timing belt position) with the engine stopped. Do not use a timing light for that.
When using a timing light to set the spark timing, you must close the ECU test jumper. The CEL should light up steady because of that while you run the engine to check the timing.
honda_farmboy's Avatar
Banned
you have to put the timing belt on properly. Put it over the cam, and put it around the crank, then everything else. Make sure the engine is timed properly before you do this.
I had to do a double check when I replaced my timing belt, and I was glad I did because somehow it slipped a tooth.
Old Aug 9, 2010 | 06:38 PM
Dannicus's Avatar
The FSM procedure says to put it on the crank first and the cam pully last.
Old Aug 9, 2010 | 08:48 PM
Dannicus's Avatar
Dammit! Went and checked it out. The cam was certainly off a tooth, again! I set it straight, tho. It's timed up good now, but I dropped my timing light and broke it. Not my day.
Coodawg20
Mar 21, 2013 10:06 AM
Beetroot
Sep 13, 2011 12:32 PM
Apostle
Aug 4, 2008 09:50 PM
Jesse_M
Jul 31, 2008 02:33 PM
tombakers
Nov 13, 2007 02:51 AM
