whats wrong with my throttle body
my idle air control valve system seems to be not giving my car enough air and so when i take out the little vacuum hose the car goes up to 1500 rpm, but when i put the hose back in it goes to only 100 rpm, and i have to lightly press the gas pedal to keep it going. Its a 1990 honda civic. Whats wrong with it? I made a video of it so it might help explain the problem better.
http://www.youtube.com/watch?v=dTKroVxRmsw
i cleaned my iacv with carb cleaner last week and it didn't do nothing. My air filter was changed, no hoses seem to be loose.
yeah i have the cel still, but when it was rung up it said my problem was the catalytic converter, got my setup hooked up gotta get it checked, tomorrow actually.
and i have a new aem sri hooked up and its closed tight. still have the rpms idling when i start the car between 1-2 and while stopped at a light between 1-2.
thanks for the help 94hatchback but swapping my pcv valve did nothing, whats a "cel"? its a car engine light right? yeah mine does have one, it doesn't light up when i turn on the car. i was thinking maybe the problem is the hose itself? take a look at it
http://img137.imageshack.us/img137/1562/image022vy.jpg
it has a valve, which is a one way air passage. Its on the correct way but every other honda civic just has a normal hose? http://www.texasracers.net/articles/.../mpfi-fitv.jpg (not my pic)
You see? mine has a valve, that one has a normal hose? could that be the problem? I blow inside mine and air goes in but i kinda have to blow hard.
oh and 94hb, do you mean when you close your butterfly wing plates inside the throttle plate http://img.photobucket.com/albums/v2...e/P1010289.jpg
( not the circled thing, its not my pic, but inside the throttlebody, the two plates that look like wings) do you mean when you close those with your finger tight, the rpm is supposed to go down? cause mine does?
harvey idk why they have that diaphram in that vacum line, if you have no cel when you turn the key on, then you need to pull out your cluster and check to see if it has a bulb, and put a bulb in it, also pull up your carpet and look at the red blinking light on your ecu, turn your key on and count the blinks, 1/2 sec blink =1 and 1sec blink =10
let us know
loosen your throttle cable a little it may be to tight and causing your rpms to be high.
let us know
