whats wrong with my throttle body
Old Nov 11, 2009 | 08:01 AM
JayVee's Avatar
jay take your sri off and inside the intake mani push that flap closed with your fingers does the rpms lower?
i tampered with it before, and it didn't lower significantly.
Old Nov 11, 2009 | 09:18 AM
This is to JayVee, who has an entirely different setup than the OP and really should have started his own thread about it. Anyway on a MPFI, when you take the intake off you will see there are two holes in the side of the throttle body before the throttle plate. The one on the back leads to the IACV and the one on the bottom leads to the FITV. Start the engine and see which one is drawing air.
If the FITV one is drawing air with the engine warmed up, FITV is bad.
If you block both side holes, the engine should stall. If it doesn't, there is an air leak somewhere else. Air leaking into the manifold from anywhere will cause the engine to idle too fast.
Old Nov 11, 2009 | 09:49 AM
that was my next suggest, you beat me to it
Old Nov 11, 2009 | 09:33 PM
JayVee's Avatar
sorry for the thread jack.!
thanks mk378.
StifflersMom
Oct 9, 2006 10:52 PM
igaryy
Dec 12, 2005 12:03 PM
pbrooks259
Oct 3, 2005 11:06 AM
hcwrecker83
Jul 31, 2005 08:38 PM
killatacticz
Jul 21, 2005 09:58 PM
