Where is the main relay on 98 civc?
Hi. I found this
1998 civic main relay location image by ajohnmeyer on Photobucket
says its by the under dash fuse box
and this
Honda Civic main relay Location
so which one is it ?
and this
I'm not sure if the distributor is getting power but its a brand new distributor and we have no spark. I found the main relay behind the glove box and it clicks and I hear the fuel pump prime and their is gas on the plugs when i pulled them after cranking the engine.
I have no spark and we tried two distributors with no luck. WE changed the fuel filter. We tried everything really.
Now I am looking for the ecu ecm supposedly under the carpet on the passenger side but I pulled up the whole carpet and there is nothing there.
I'm so frustrated!!
I'm so frustrated!!
all fuses are good. The battery is charged. There is no fuel problem as far as I know.
Is the main relay only for the fuel pump? b/c the fuel pump primes and gas is flowing to the injectors and wets the plugs. WE changed the fuel filter too.
Can I rule out the main relay?
ktorres1120
Sep 4, 2013 08:07 PM
ICONOMAT
Dec 13, 2004 10:44 PM
