why is it not startin?
got a 94plate 1.5lsi used a different battery to start it then changed it back to my battery while the car was running,put the negative on then when i put the positive the car cut out and definatly blew something? the fuses for the ecu and the back up keep blowing when i turn it over? do you think i've blown the ecu?
RE: why is it not startin?
Chances are you blew more fuses then you can shake a stick at. including the 80Amp fuse that is like $10 just for one fuse, you are lucky if you didn't kill your ECU from the surge of power too
ORIGINAL: kinosh
You shouldn't be screwin' around with car batteries like this. You're lucky if a fuse was blown.
