Why wont power windows work unless door is wide open?
Old Sep 5, 2010 | 07:58 AM
couly's Avatar
Question Why wont power windows work unless door is wide open?
My 98 civic's power windows wont work unless the drivers door is wide open. I Thought the hot wire to the switch must be broken at the door hinge point so I checked the switch plug for power with a test light with the door fully open. 4 of the 14 terminals had power(all windows work)good. Closed the door, checked for power again. The same 4 terminals still had power( no windows work)bad.
I dont get it.
Can anyone enlighten me?
Thank you,
Jeff
Old Sep 5, 2010 | 11:07 AM
It's definitely a broken wire. The wire will look OK on the outside but the copper is broken inside. I think on the 98 you can buy the little harness that goes to the door separately.
Old Sep 5, 2010 | 01:33 PM
91crx_83's Avatar
Also a test light will only tell you that power is going to it, if there is a break or corrosion in the wire the light will come on but you may have less power than required to make said part function correctly. In my opinion I would also check how much power is going to the switch with a multimeter
mrossi22
Feb 4, 2015 10:28 AM
lktng
Jul 14, 2013 11:49 AM
canderific
Jan 5, 2013 12:15 PM
basbal123
Nov 2, 2007 04:09 PM
howard55
Feb 1, 2007 07:04 AM
