DRIVER SIDE DOOR WONT OPEN!?!?!?
Old Nov 1, 2007 | 09:26 AM
basbal123's Avatar
Default DRIVER SIDE DOOR WONT OPEN!?!?!?
ok guys i was driving on a back road and i hit an unleveled surface and BUMP nut now for some reason my drivers side door wont open from the inside it still opens from the outside but not the inside does anyone know how to take the panel off so i can look....... or does anyone even know what the problem can be??
by the way i have a cx so no electrical just straight hardware
Old Nov 1, 2007 | 12:06 PM
SilverWrench's Avatar
Banned
Default RE: DRIVER SIDE DOOR WONT OPEN!?!?!?
looks like you need blonde star[sm=roll.gif]
Old Nov 1, 2007 | 12:25 PM
desert2007's Avatar
its gotta be the mechanizim, cant be the hinges or the door binding since it opens from the outside, you gotta just take off the panel and see whats wrong inside there.
Eric.
Old Nov 1, 2007 | 03:33 PM
basbal123's Avatar
does anyone know how to take it off i dont want to take it off and break something
Old Nov 1, 2007 | 03:58 PM
should be afew screws.... one behind door handle opening.... one screw in the door grip handle... and then 2 or 3 behind the speakers grill around the speaker. all philips screws and then pull the doors mirror trim piece UPwards and it should come off.... and THEN use a flat screw driver and pry under the bottom of the door panel and pop it back and forth to pop a few clips loose THEN the door panel should just come off..... pull the bottom of the door panel out from the door afew inches then pull the door panel upwards which will clear the window sweep and thier ya go.... should be right off...
most likely your plastic rod retainer clips just broke or came off and the rod poped off. very simple fix..... but IF its not the problem... then your latch MIGHT have busted.... or just dry and stuck. spray it down some with good penatrating oil and bolt it back in.... and work the latch afew times....
Old Nov 2, 2007 | 12:45 PM
basbal123's Avatar
ok this is wierd but i took it apart and the actual latch itself the 3 holes where they bolt to the side of the car became stripped so there was nothing to hold the latch back shile i pulled on the lever so apparently i have to get a all new latch. or is there a way to un strip it, i dont know if its plastic or not??
Ozzie7876's Avatar
You can use this tutorial to help you get the door panel off....
https://www.hondacivicforum.com/m_392134/tm.htm
Old Nov 2, 2007 | 12:48 PM
basbal123's Avatar
i know how to take the panel off thats how i got the latch off im talking about the 3 holes in the latch there stripped is there wa way to unstrip them or should i just get a all new latch
Old Nov 2, 2007 | 04:09 PM
ya just get a new latch.....
ashu
Aug 8, 2010 08:52 AM
civicmanchris
Jun 25, 2008 04:15 PM
RogerBurks
Sep 3, 2007 06:32 PM
griz
Apr 24, 2007 08:05 AM
95delsolDOHCvtec
Jun 29, 2006 12:06 PM
