Window not working
Old Mar 8, 2006 | 01:28 PM
rice_patrol's Avatar
Default Window not working
alright another problem to my car, somethings wrong with my window, you can open it but then the window falls down, then i opened up the door panel and place it back, but it back up and wouldnt go straight up. So whats the problem here, i dont know the terms to what the parts are. kinda dumb here, but yeah i need that window to work. i've tried many times but didnt seem to make it work. So please help me on this. Also another question, why is there water in my spare tire compartment? Thanks!
Old Mar 8, 2006 | 03:01 PM
natecivic92's Avatar
Default RE: Window not working
Sounds like it to me there is a clip that holds glass bottom track it probley is that plastic clip.I would take door trim off and look at it.2 its probley rusted the bottom of that capartment
Old Mar 8, 2006 | 04:47 PM
baker's Avatar
water in your trunk is from your aftermarket tails.
Old Mar 9, 2006 | 12:36 AM
patcheway's Avatar
or if you have a sunroof the drain plugs could be clogged also are there two bolts that hold the glass to the regulator in your door? if so there should bu urathane that hols the clips to the glass if the clips are off the glass have a glass place glue them back on and bolt it up yourself it is not that hard i work as a windshield installer and we also install door glass. so i have done this a few times.
Old Mar 9, 2006 | 08:02 AM
i dotn have any tails on my car, its a honda civic hatch cx, no power or anything, so the clips on the window are probably off then? and dont know where the water came from.
Old Mar 9, 2006 | 11:20 AM
I think if I remeber right there is a plastic drain plug below you spare tire.
Old Mar 10, 2006 | 09:57 AM
nigel_miguel's Avatar
the reason for the leak in your trunk, could be rubber seals around the hatch. Do you have a good seal?
Old Mar 10, 2006 | 10:24 AM
jusplayn85's Avatar
I have water in my hatch as well... It's because part of the weld around the spare tire compartment came apart. like 2 1/2" inches. Gotta get it welded soon, but for now it's spray foam Gotta keep the salt outta my car at least, can't keep it off.
gunaa
Oct 22, 2009 11:36 AM
JamesDizzean
Sep 30, 2007 04:57 AM
Hobo
Sep 26, 2007 04:55 PM
Schimmel03
Feb 10, 2007 07:00 PM
chrisroug
Oct 2, 2006 11:36 AM
