window trim
Old Aug 3, 2006 | 02:09 PM
tripod's Avatar
Default window trim
i have a 96 civic ex coupe. the trim on the outside at the bottom of the driver and passenger window is starting to dryrot and come off. its a metal strip with some black rubberizd coating. did/does anyone else have this problem and if so what can i use to touch it up. im thinking about using some black silicon, but dont want it to look like crap
Old Aug 4, 2006 | 11:11 AM
tripod's Avatar
Default RE: window trim
nobody else has this problem?
Old Aug 4, 2006 | 11:32 AM
fglaustin's Avatar
think they deteriorate on most older vehicles.
no fix solution that i know of - just need to replace; and as far as i know it is a dealer item.
Old Aug 4, 2006 | 03:49 PM
civicex96's Avatar
Just had both of mine replaced. I have a 96 Civic EX coupe. The parts for both the rubber pieces were about $60 and installation another $80. It's pretty hard to get it in there. But if you know what you are doing, I'd just go to the dealer to buy the parts and install them yourself to save $80.
Good luck!
Old Aug 5, 2006 | 02:59 AM
mikeyb16a2's Avatar
i have same problem with mine all the rubber coating is peeling off the metal strips, i was thinking about taking these off sanding them all down and respaying with a silicone based paint, the hard part looks like getting them off with out bending them
Old Aug 5, 2006 | 07:43 PM
mill$civic's Avatar
buy new ones..if its not to bad, you can buy this stuff called "back to black"
http://www.mothers.com/detailguidedo...deCh6_Trim.pdf
GOTeg?
May 19, 2008 05:19 PM
n8te81
Sep 20, 2007 05:13 PM
beerguy6903
Aug 20, 2007 09:48 PM
larlar73
Jun 7, 2007 02:19 PM
Wuahaha
Dec 29, 2006 06:43 PM
