Wiper Problem
Old Jan 22, 2008 | 02:22 PM
pb24's Avatar
Default Wiper Problem
My intermittent position on my wiper switch does't work. I dont think its the switch, Is their a relay or timer that can be bad? All other positions on the switch work. Car is a 1992 Civic 3 door.
Old Jan 22, 2008 | 05:55 PM
Default RE: Wiper Problem
Therre is a module under the dash to control that. It may be combined with the beeper/etc. module on the back (or front, depending on your perspective) of the fuse box. Once you find it, it can likely be repaired by pulling it out and resoldering like you would a main relay.
Old Jan 22, 2008 | 07:21 PM
First you may want to rule out a problem with the switch. The pictures describe some continuity tests for this purpose.
95ownermn
Mar 10, 2008 07:55 PM
jgscisum
Dec 3, 2007 10:20 AM
D16z6
Dec 4, 2006 07:02 PM
reparent
Dec 22, 2005 03:56 PM
