wiper problems
Old Nov 16, 2008 | 02:34 PM
mundy5's Avatar
go to my signature and download the 92-95 factory service manual. it should give you some diagnostics.
Old Nov 16, 2008 | 04:58 PM
Originally Posted by Dipsetcivic117
changed the switch and the motor and still dont work...i hear a clickin noise when on the slow speed. so i kno its not the switch or the motor. must be suttin in between...
Now that you have replaced both the switch and motor, is the only problem that the low setting does not work? Or are there additional problems?
How do you know the replacement motor and switch are good?
Have you checked whether the black ground wire from the motor has continuity?
Old Nov 16, 2008 | 06:13 PM
Dipsetcivic117's Avatar
yea...the low setting does not work and the the wipers do not return to the home position...i checked to make sure they worked on the car i took em off of...
Old Nov 16, 2008 | 06:39 PM
Check whether any terminals or wires of the indicated connectors are damaged or broken:
NJCurmudgeon
Apr 30, 2012 07:50 AM
asechrist
Nov 27, 2011 08:24 AM
95ownermn
Mar 10, 2008 07:55 PM
BillyB98
Jan 21, 2008 02:21 PM
