A wire is broken
Old Oct 21, 2011 | 07:05 PM
lp23601's Avatar
Default A wire is broken
I have a 1987 Honda Civic stationwagon, manual transmission, 1.5L engine, front wheel drive, 340K miles. When I was doing some transmission and clutch work I broke/cut one wire. The wire comes from a cable with four wires in it (4 wires wrapped with plastic tape). Out of four wires two go to a thermosensor beneath the distributor, one goes to a temperature gauge beneath the distributor and next to the temperature gauge towards the back, the last one is the broken one. I can't find other end of the wire connection in its perimeter.
Then the problem was that idle was too low. So I adjusted the idle screw to increase the idle to 1500RPM. Even so the car dies quite often when idling.
Thanks for answering. Hope someone has a same car would be able to help me. Thanks in advance.
Old Oct 21, 2011 | 07:09 PM
I think that the other wire goes to the oxygen sensor on the exhaust manifold. Is it carburetor or fuel injection?
Old Oct 21, 2011 | 09:53 PM
lp23601's Avatar
My aologies. It should total 5 then. I checked the oxygen sensor wire it is connected.
It would be a super easy answer if someone has a same car.
asdfbrendan
Aug 24, 2007 02:41 PM
xsdudztx
Aug 14, 2007 05:45 PM
xsdudztx
Aug 9, 2007 07:45 PM
herbaleyes
Nov 26, 2006 12:33 AM
seaners173
Jul 14, 2004 09:16 PM
