Wiring CX vtec
Hey, I was just curious how I go about wiring my vtec
I had a d15b7 and swapped it with a d16v6, also swapped cpu from p08 to p28.. It's a CX (canadian version,) So I'm aware that I will have to get a 4 wire o2 sensor, but how exactly do I wire the vtec into my existing CX wiring harness? Does anyone know of any step by step instructions?
it's "d16z6"
i copied/pasted this from this link: http://www.honda-tech.com/zerothread?id=563840
VTEC wiring is faily simple. It's three wires.
First locate the VTEC solenoid (1 wire) and the VTEC oil pressure sensor (2 wires).
Simply take the Grn/Yel wire from the VTEC solenoid on the engine harness, and lead that to the A4 pinout at the ECU.
For the VTEC oil pressure switch, take the Blu/Blk wire from the VTEC oil pressure, then leads to a ORG/BLU wire, lead that to the D6 pinout.
As for the BLK wire, lead that to the thermostat ground.
trustdestruction
Jan 29, 2009 12:02 PM
