Wiring diagram for a 96 Civic EX 5 spd
Hey guys, sorry if this is in the wrong forum.
I am going to attempt to install an alarm in my car by myself. Just want to know if anybody has a wiring diagram for the 96 Civic EX Coupe 5 spd.
Has anybody installed an alarm in their car by themselves? And if so, how hard is it?
I have experience with installing a radio, subwoofer and speakers. And since this is an old car, I'd figure I'd try and learn how to install an alarm by myself.
Any help will be greatly appreciated.
Thanks!
Thanks!
Hope this helps:
WHAT - WIRE COLOR - pos or neg - LOCATION to find wire
12volts white (40A) + ignition harness
Starter black/white + ignition harness
Ignition black/yellow + ignition harness
Power Lock green/white - driver kick, blue plug
Power Unlock green/orange - driver kick, blue plug
Lock Motor white/red 5wi driver kick, door harness
Unlock Motor blue/red to yellow/red 5wi pwr door lock ctrl unit in driv door
Disarm Defeat yellow/red 5wi driver kick, door harness
Parking Lights+ red/black + driver kick, fuse box
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) green/red + steering column
Turn Signal(R) green/yellow + steering column
Door Trigger lt. green/red - factory alarm plug
Dome Supervision lt. green/black - driv A pillar or factory alarm plug
Trunk/Hatch Pin blue/black - driver kick, harness to rear
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock factory remote only
Tachometer blue ac test tachometer connector
Horn Trigger blue to gray - steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Parking Lights- N/A
Hood Pin N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Above for 96:
Below for 00:
12volts
white
ignition harness
Starter black/white + ignition harness or
Power Lock green/white - keyless entry module
Power Unlock green/orange - keyless entry module
Lock Motor white/red drivers kick panel
Unlock Motor blue/red drivers kick panel
Disarm Defeat yellow/red keyless entry module
Parking Lights+ red/black keyless entry module
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger lt. green/red - OEM alarm plug
Dome Supervision same as doors
Trunk/Hatch Pin blue/black - OEM alarm plug
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Disarm No Unlock
Tachometer blue test connector
Horn Trigger gray - OEM alarm plug
Memory Seat 1
Memory Seat 2
Memory Seat 3
For 92:
12volts
white
brn conn abv fusebox
Starter black/white + brn conn abv fusebox
Ignition black/yellow + brn conn abv fusebox
Power Lock green/white - in drivers door
Power Unlock green/red - in drivers door
Lock Motor
Unlock Motor
Disarm Defeat
Parking Lights+ red/black grn plug top of f-box
Parking Lights- white/black anti-theft module
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger lt green/red - driver kick panel
Dome Supervision
Trunk/Hatch Pin grn/blk 2 silv dots - blu conn above fusebox
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer blue AC 2-pin plug near distr.
Horn Trigger blue/green - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
for 2003:
12volts
white
ignition harness
Power Lock white/blue - gray plug above driver kick
Power Unlock white/green - gray plug above driver kick
Lock Motor yellow/black 5wi back of the fusebox
Unlock Motor yellow/green 5wi back of the fusebox
Disarm Defeat yellow 5wi back of the fusebox
Parking Lights+ red/black + back of the fusebox
Parking Lights- blue - factory alarm plug
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger - factory alarm plug
Dome Supervision comes on with unlock
Trunk/Hatch Pin red - factory alarm plug
Hood Pin N/A
Factory Alarm Arm
Disarm No Unlock
Tachometer blue ac test connector
Horn Trigger orange - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
for 2005:
12volts
white (40A)
ignition harness
Power Lock white/blue - driver kick, door harness
Power Unlock white/green - driver kick, door harness
Lock Motor yellow/black 5wi DKP or back of fuse box, top left
Unlock Motor yellow/green 5wi DKP or back of fuse box, top left
Disarm Defeat yellow 5wi PKP or back of fuse box, top left
Parking Lights+ red/black + back of fuse box, top middle
Parking Lights- blue - switch or factory alarm plug
Turn Signal(L) green/red + turn signal switch
Turn Signal(R) green/yellow + turn signal switch
Door Trigger see notes - frt of fusebox or factory alarm plug
Dome Supervision green/red - back of fuse box, top right
Trunk/Hatch Pin red - frt of fusebox or factory alarm plug
Hood Pin N/A
Horn Trigger orange - switch or factory alarm plug
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
alarm wiring for 2006 honda civic:
12volts
white (50A)
ignition harness
Starter yellow + ignition harness
Ignition blue + ignition harness
Power Lock green - dr kick or MICU, 34 pin plug, pin 28
Power Unlock gray - dr kick or MICU, 34 pin plug, pin 27
Lock Motor blue 5wi DKP or fuse box, rear 14 pin plug
Unlock Motor yellow 5wi DKP or fuse box, rear 14 pin plug
Disarm Defeat yellow 5wi PKP or fuse box, rear 10 pin plug
Parking Lights+ red + dr kick or fuse box, top 42 pin plug
Parking Lights- gray or red - switch or MICU, 20 pin plug, pin 13
Hazards green + switch or fuse box, rear 16 pin plug
Turn Signal(L) blue + dr kick or fuse box, top 42 pin plug
Turn Signal(R) brown + dr kick or fuse box, top 42 pin plug
Door Trigger see notes - ea kick or fuse box, top 42 pin plug
Dome Supervision pink - fuse box, rear 8 pin plug
Trunk/Hatch Pin blue - dr kick or fuse box, top 42 pin plug
Hood Pin lt. blue - pin sw or fuse box, mid 21 pin plug
Trunk/Hatch Release green + dr kick or fuse box, top 42 pin plug
Factory Alarm Arm orange - dr kick or MICU, 34 pin plug, pin 32
Factory Alarm Disarm brown - dr kick or MICU, 34 pin plug, pin 31
Disarm No Unlock see factory alarm disarm
Tachometer NOT blk/wht, black or yel/blk ac any ignition coil or fuel injector
Horn Trigger orange - switch or fuse box, rear 16 pin plug
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Okay, everyone should be happy when they find this post!
Below for 00:
12volts
white
ignition harness
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Disarm No Unlock
Memory Seat 1
Memory Seat 2
Memory Seat 3
For 92:
12volts
white
Lock Motor
Unlock Motor
Disarm Defeat
Hazards
Turn Signal(L)
Turn Signal(R)
Dome Supervision
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Disarm No Unlock
Memory Seat 1
Memory Seat 2
Memory Seat 3
for 2003:
12volts
white
ignition harness
Hazards
Turn Signal(L)
Turn Signal(R)
Hood Pin N/A
Factory Alarm Arm
Disarm No Unlock
Memory Seat 1
Memory Seat 2
Memory Seat 3
for 2005:
12volts
white (40A)
ignition harness
Hood Pin N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
12volts
white (50A)
ignition harness
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
hmdaigle
Sep 23, 2008 08:04 AM
vk4bcp
Jul 6, 2004 03:31 PM
