won't idle
Old May 27, 2004 | 08:03 AM
sdm329's Avatar
Default won't idle
I own a 89 civic si. I just rebuilt the top of the motor. as long as it is not idling it sounds great, once i try to let it idle it stalls or is very irratic could my timing be a little off or maybe my MAP sensor, i'm stuck someone please help!
Old May 27, 2004 | 12:25 PM
NTX's Avatar
NTX
Default RE: won't idle
The timing could be the problem. That would be the firts place to look...
Old May 28, 2004 | 05:47 PM
lilol89crx's Avatar
^^^^ i agree also double check your vacum lines. was there any valve adjustments done after the head was rebuilt? an old v8 trick for more hp is to run tighter clearances on the lifters. when you close the valve lash tighter it will cause the car to not idle properly, something to thinnk about.
my86civic
Oct 8, 2008 06:44 PM
ACE_92
Mar 28, 2007 06:06 AM
mikeym
May 31, 2006 09:09 AM
joey
Oct 14, 2005 03:31 PM
Mxsex
Mar 11, 2005 05:35 PM
