wont start
Old Sep 10, 2009 | 02:07 PM
wjw11teen's Avatar
Default wont start
I have a 93 civic w/ 2.2 liter
it wont start
it cranks good but wont start
where should I START LOOKING
I believe its getting fuel, because it fired very breifly when I first crancked it over
but now ...... nothing
athis is my sons car, and neither of us are familiar w/ foriegn cars
its been super reliable so we would like to get it running again
It seems like the prob might be in the ign. system,but not sure what part
is there a typical problem that we could try first
thanks in advance for all the help
Old Sep 10, 2009 | 04:12 PM
A 2.2 liter is not a stock engine. Stock were 1.5 and 1.6 liter.
Anyway you should start by checking for spark like on any other car, pull one of the wires off, plug into a spare spark plug, and hold the plug on the engine.
When you click the key on but don't crank you should hear the fuel pump (inside the fuel tank under the back seat) run for 2 seconds.
Old Sep 11, 2009 | 04:41 AM
wjw11teen's Avatar
O.K. thanks forthe help
It is a 1.5 litre
ill check spark and fuel today
how much fuel pressure should it have?
is there a typical igtnition part that goes out that I can check first
like pick up coil or something similar? is the coil under the cap? I couldnt find one externaly
thanks again
Old Sep 11, 2009 | 05:06 AM
High voltage coil is under the cap and it is probably the weakest link in the ignition system. If you have a no-start, no spark also check that the timing belt is not stripped, if the distributor doesn't rotate there will of course be no sparks.
To check fuel I like to disconnect the return hose that goes from the regulator back to the tank. If fuel comes out there when the pump is on you know the pressure is sufficient to operate the regulator, thus unless the regulator is bad (rare) everything is OK.
I think pressure should be about 44 psi with the engine not running (from there it decreases proportional to manifold vacuum). To measure with a gauge you will need an adapter to couple the gauge to the fuel filter.
David_S
Oct 24, 2013 10:06 AM
bmelloh
May 16, 2009 08:01 PM
niteryder
Dec 29, 2004 06:47 PM
AndyI
Oct 6, 2004 09:36 AM
89 pos
Jun 25, 2004 05:35 PM
