wtsup civic fam
Check that the tail lights work. They are on the same circuit.
If the only problem is that the dash lights suddenly went out, it could be the dimmer control. Pull the dimmer out and jumper the solid red wire to the solid black wire to bypass it. The dash lights should now come on full bright when you turn the light switch on. If they do, replace the dimmer control.
