12A Turbo
I have a 12A turbo and was wondering if I could drive this as a daily driver. What I am getting at: Can I drive this without constantly being in boost? As you know the 12 A turbo is very small and will spool very fast. I was wondering if I should go with a different turbo for this application. I just want to have my car be as reliable as possible when I boost my civic. Thanks!
The Wankel motor was invented by Dr. Wankel. It is the rotary engine Mazda typically uses. However it is commonly mistaken that Mazda invented the motor, Dr Wankel was German and had nothing to do with the Japenese. Mazda simply was the first and so far only (to my knowledge) to incorporate the 'rotary' engine on a mass production scale. The benefit of the wankel motor is that there is no reverse action as found in standard piston engines. The result is a higher RPM with ease. However, they are inefficient and a royal pain in the **** to tinker with in most cases.
