2000Honda Civic EX TURBO
Old Mar 13, 2009 | 02:06 PM
silverbullet01's Avatar
Default 2000Honda Civic EX TURBO
i have a 2000 honda civic ex 2dr coupe and its BONE stock as of right now. the car has 84000 miles on it 5spd tans. very good condition all around and perfectly mechanically. i was either going to sell it for 5,700 and i buy a stock fast car or i was going to get a turbo. im really wanting to buy a VW. what should i do?
Old Mar 13, 2009 | 02:11 PM
mudferret's Avatar
what should i do?
If you really enjoy modifying a car, get the turbo. If you just want something fast that won't require much work, sell it. Chances are you'll find that the new, fast car has a lot of aftermarket support as well. It's a vicious cycle.
Old Mar 13, 2009 | 03:45 PM
intenseneal's Avatar
I would boost the Ex it is a great motor to turbo as are all d series engines. With only 84k on the motor it is perfect to turbo. Check out turbod16.com
Old Mar 14, 2009 | 10:50 AM
ok im thinking about boosting my car. now the problem is i dont know anything about turbos and all the parts you need etc. so if i were to part together a turbo set up. what would be my steps? and how much would it run me by piecing one together? i want to be around 200+hp area. keep in mind car is Daily Driver and is ALL bone stock.
Old Mar 14, 2009 | 10:56 AM
FlipHKD720's Avatar
have you read the Nitrous/Supercharger/Turbo FAQ?
Old Mar 14, 2009 | 10:59 AM
i have alittle bit. here all you honda turbo people that know what is good and bad. would this be a bad set up if i pieced it together?
An IHI turbo w/ cast downpipe that was on a Honda Civic 1.6. This originally came off a MAZDA mx6 turbo, my friend used it with a different manifold on a Civic. We upgraded his stuff, so these parts are for sale! first: IHI Turbo (internal wastegate 8lbs., used a boost controller (not included) to get 11 to 12 lbs). This turbo works w/ almost any 1.6 - 2.2 liter motor, but you need to get the right manifold (off ebay maybe) for your car. Second:. Cast MAZDA 2.2 manifold. Third:. Cast IHI turbo Downpipe, with o2 sensor. Fourth:. Front Mounted Intercooler (from a mazda, worked great on the civic!) Fifth:. blow off valve (not shown). All works great. You will need intercooler tubing and connnectors (once again, ebay), an oil line kit (I have a brand new stainless hose/alloy fitting one I could sell for $80 ,, cost over $100 new) and a boost controller ((if you want to go over 8 lbs of boost)). This will let you turbo your Honda Civic 1.6 for way cheap!!! Just the turbo would sell for what the whole kit is going for
Old Mar 14, 2009 | 11:07 AM
FlipHKD720's Avatar
HF manifold w/ custom adapter plate with the IHI turbo ftw. I had an IHI turbo at one point, pretty small, does the trick, convenient. FMIC can be found on ebay or HomeMadeTurbo, Turbod16.com, etc., BOV can be found in the same places (classifieds), 2.5" charge piping with T-Clamps, Stealthmodeperformance.com has good oil line kits, and a boost controller isn't necesarry unless you're going to up the boost, but its smart to have if you plan on making changes to your setup in the future.
Old Mar 14, 2009 | 12:48 PM
lol... you've never owned a VW before, have you? I've never heard a VW owner say anything about wanting to buy another one... I wonder why that is
At any rate, read through the stickies for what you need to boost
Old Mar 22, 2009 | 04:14 PM
CivicJunkie's Avatar
Volkswagens are good, my friend has a 2008 GTI. Its beaten a 350z, infiniti G35, and a heavily modded acura rsx.
Old Mar 22, 2009 | 04:34 PM
rburch77's Avatar
Have you ever checked out Volkswagons warranties? they are horrible! its something like 3 years, 35,000 miles!
