Anyone here using the ZEX dry kit on a y8?
n2o........ A 55 shot does not mean a 55whp gain, n2o like so many other mods are for 1 rated at the crank and for 2 depend on much more that the "shot" you use. A 55 shot dry will be fine on the stock fuel pump, injectors, and maybe ok on the stock tune. The 96-00 ex's use a rising rate fuel system meaning if the map notice's a rise in air in the air/fuel mix it will compensate to a certain point and it should be fine with a 35-55 dry shot. but I honestly suggest you go with a 75 shot wet kit. You will see more of a gain for your money, it will be safer, and in the end it dont cost to much more.
I got the kit, FPR, and gauge in. In about a week, it should be tuned on the dyno ready to go to the track to see what she can run. I can't wait. Im gonna run the 55 shot and sometimes the 65 shot. Ign will be retarded at least 1 degree and I'll be using 2 step colder NGK plugs. I'll let you guys know what kind of numbers it puts down as soon as it's all tuned up and eveything! Thanks for all the responses!
sjmcgarrah
Jul 24, 2007 06:13 PM
longears
Jul 17, 2007 06:55 AM
