driving in vaccum
Old Apr 25, 2007 | 12:36 PM
Default RE: driving in vaccum
It is 100% impossible for him to not be driving in vacuum
Old Apr 25, 2007 | 01:26 PM
FlipHKD720's Avatar
ORIGINAL: SovXietday
Turbo's are load based, IE throttle based. You can be at 7000rpms but if you're only at 15% TPS you won't be boosting.
i imainge that stands for something dealing with how hard you push down on the gas pedal? Thanks for the info guys....my bad bout givvin the wrong info too
EDIT: and load, meaning how hard the gas pedal is pushed as well?
Old Apr 25, 2007 | 02:35 PM
Remmy's Avatar
Like the others said, I too can go all the way to 9,000 RPM and not hit boost.
Old Apr 25, 2007 | 03:32 PM
ScoobyAddict14's Avatar
formerly aryiman98civic
ORIGINAL: Remmy
i can cruise at 70 mph on the highway without touching boost at all and i am only at like 10 psi vacuum.
Old Apr 25, 2007 | 03:52 PM
Kedawei's Avatar
ORIGINAL: Forty04
ORIGINAL: FlipHKD720
^ Saabs unite! haha
But again, low RPM boost/quick spooling turbos would be bad for your DD's MPG
NOPE! Turbos are spooled by "load" not rpm . I've said this before but I'll say it again, with my tiny *** t25 turbo, I could go all the way redline without ever touching even a pound of boost, none!
Even cruisin in 5th gear?
Old Apr 25, 2007 | 03:53 PM
Kedawei's Avatar
ORIGINAL: aryiman98civic
ORIGINAL: Remmy
Vacuum is a negative pressure, not positive. I don't think you are sucking air out of your motor heh.
Where is all this vacuum stuff coming from anyway?
Old Apr 25, 2007 | 03:54 PM
ORIGINAL: Kedawei
ORIGINAL: Forty04
^ Saabs unite! haha
yeah, As long as I didnt punch it. 5th gear is a bit harder to do it in, but its definitely possible
Old Apr 26, 2007 | 06:19 AM
ORIGINAL: Kedawei
Are you saying that its impossible to accelerate in vacuum?
Old Apr 26, 2007 | 08:33 AM
Mr Mobsta Man's Avatar
All n/a cars work in vacuum, they are sucking air in instead of it being forced in.
Old Apr 26, 2007 | 09:23 AM
FlipHKD720's Avatar
pushing down hard on the pedal gets you into boost, but slowly creeping up one the RPMs will keep you in vaccum? Correct?
