is this everything?
https://redhat3.admarkonline.com/~treadstone/product.phtml?p=23&cat_key=134&prodname=Ho nda+Civic+SI%2C+B%2C+D%2C+CRX+Series+Turbo+Kit
so is this everything i need to run on a stock D16y8 motor in a 99 civic ex coupe? is there ANYTHING else i need to buy? It says no fuel components come with this kit, so what would i need to get? Also how much PSI should i run if i want to get around 180hp. Any answers would be greatly appreciated
from wut i hear an fmu and piggyback are not the way to go, will casue problems down the road, get ur ecu chipped with the proper air fuel ratios and upgrade fuel injectors. eupgrade ecu using a software program such as uberdata,crome or hondata from wut i hear
Unless you know people and/or where to look..
Chipped p28 ecu with a basemap - ~$170-$200
DSM 450cc Injectors w/ Resistor box and clips - ~$80-$100
OBD2a->OBD1 conversion harness - $100
Tuning charges - $300+ (300 is pretty much the bare minimum
I'll say it till I'm blue in the face, do the research, and build your own kit.
Also, I would ask this "guy who knows ecus" about how many cars he's tuned, and how they are running. I'd even talk to the car's owners, and see what their views are. Make a wrong move on the tune, and you're motor will look like mine...swiss cheese
www.phearable.net
^ chipped OBD1 ECU's with a conversion harness. Tell him your setup and mods and he'll send you a good basemap that you can bring and go get tuned. I've only heard good things about that website
ORIGINAL: FlipHKD720
www.phearable.net
www.phearable.net
