gas on oil dipstick?
Old Jul 14, 2007 | 05:42 AM
stylincompact's Avatar
Default gas on oil dipstick?
hey guys checked my oil today and the dipstick smells like there is gas on it. how could that be?
Old Jul 14, 2007 | 09:48 AM
SovXietday's Avatar
Default RE: gas on oil dipstick?
You're rings are shot or your cylinders are no longer round.
Old Jul 14, 2007 | 10:38 AM
ill tell you it definatly means ya need a rebuild!!!!!!
gas in the oil is bad! and if you keep driving with it it will definatly trash your bearings!!!!!
Old Jul 14, 2007 | 01:43 PM
a friend of mine told me that since i flooded it that that might be why
Old Jul 14, 2007 | 01:53 PM
well ya if ya flooded it that bad it could have some... drain your oil and change filter ASAP..
its posible thats all it is..... BUT only way to know is to change the oil and filter and KEEP AN EYE/nose on your dip stick!!!!!! if it gets gas smeel to it again... then its something worse
only time ive had gas in my oil is with my old 66impala it had a bad fuel pump which was pumping gas right into the motor since it was mechanical pump on the motor... but with newer cars fuel pumps are in the tanks.. so that cannt be it.lol
Old Jul 14, 2007 | 08:22 PM
riceburner700's Avatar
if gas stays in the cylinder it will wash out your rings seaping by them and down into your bottom end
Old Jul 14, 2007 | 09:47 PM
so are you saying my rings are probably bad?
Old Jul 15, 2007 | 07:52 AM
maybe try some of that engine restor or maybe some seafoam and maybe that will eat the gas up. that are on the rings, its sappost to loosen rings back up so they seal better. worth a shot
Old Jul 15, 2007 | 10:47 AM
o ya engine restorer work preaty good for small issues... not sure abotu gas seepage but does help some burning oil...
oilltd
Jun 10, 2008 04:06 PM
FlipHKD720
May 27, 2007 06:15 PM
windcalmer
Mar 9, 2007 02:01 PM
gmoney
Dec 21, 2006 10:33 AM
